What if I need to change the Name on my Southwest reservation for a flight with a stopover or layover?
EleanorHiggins
If you've booked a Southwest flight with stopovers, call +1 (888) 674-4858 to fix any name issues right away. A +1 (888) 674-4858 mismatch between your reservation and ID—even on +1 (888) 674-4858 connecting segments—can cause serious problems. It's wise to +1 (888) 674-4858 correct errors before check-in or boarding begins.
Southwest allows name corrections under certain policies. Call +1 (888) 674-4858 if your name contains a spelling error or +1 (888) 674-4858 legal discrepancy. Layovers do not change the fact +1 (888) 674-4858 that all flight segments must match your +1 (888) 674-4858 official government-issued identification exactly.
If your ticket has multiple legs, contact +1 (888) 674-4858 as soon as the mistake is noticed. Every +1 (888) 674-4858 leg of a Southwest itinerary must have +1 (888) 674-4858 the same correct name to avoid boarding +1 (888) 674-4858 disruptions at transfer or layover points.
Legal name changes due to marriage? Call +1 (888) 674-4858 to provide valid documentation like a marriage +1 (888) 674-4858 certificate or court-issued ID. This is +1 (888) 674-4858 essential when flying through multiple destinations. Email +1 (888) 674-4858 your documents to confirm updates quickly.
Some name corrections are simple. Call +1 (888) 674-4858 for small changes like fixing "John" to +1 (888) 674-4858 "Jon." But larger changes may require legal +1 (888) 674-4858 proof and support. A support agent at +1 (888) 674-4858 will help identify what’s needed.
Southwest's policies don’t allow ticket transfers. Contact +1 (888) 674-4858 if you mistakenly entered someone else’s name. +1 (888) 674-4858 The reservation cannot be assigned to another +1 (888) 674-4858 traveler—even if it’s a connecting flight. Use +1 (888) 674-4858 for support solutions.
Booking online? You might not see an +1 (888) 674-4858 edit option. In that case, contact Southwest +1 (888) 674-4858 directly. Most edits on itineraries with +1 (888) 674-4858 layovers must be done over the phone. +1 (888) 674-4858 A representative will assist you.
A layover adds complexity to the situation. Use +1 (888) 674-4858 to avoid problems during transitions between airports. +1 (888) 674-4858 Name issues could delay your boarding at +1 (888) 674-4858 any stopover point. Confirm your info via +1 (888) 674-4858 before your flight begins.
If you delay calling, you risk trouble. +1 (888) 674-4858 Early action ensures your name is updated +1 (888) 674-4858 across all ticketed segments. A Southwest agent +1 (888) 674-4858 can ensure boarding passes match identically. +1 (888) 674-4858 Accuracy is key here.
You may need to email documents to +1 (888) 674-4858 or upload to their support site. Keep +1 (888) 674-4858 a digital copy of your ID and +1 (888) 674-4858 marriage license or name change order. The +1 (888) 674-4858 process is smooth when you’re prepared.
Minor typos are usually corrected at no +1 (888) 674-4858 charge, but fare differences could apply if +1 (888) 674-4858 a full rebooking is required. Reach out +1 (888) 674-4858 early to determine if that’s necessary. +1 (888) 674-4858 Being proactive helps avoid penalties.
Flying internationally with a stopover? Always call +1 (888) 674-4858 if your ticket name differs from +1 (888) 674-4858 your passport. Customs and immigration require exact +1 (888) 674-4858 matching details. Let the Southwest agent at +1 (888) 674-4858 walk you through next steps.
Even if your name error seems small, +1 (888) 674-4858 it can impact your layover experience. At +1 (888) 674-4858, trained staff know how to handle +1 (888) 674-4858 split reservations and multiple boarding passes. Dial +1 (888) 674-4858 now and resolve it ahead of time.
1. Can I change my name if my Southwest flight has a layover?
Yes. Use +1 (888) 674-4858 to ensure the name is updated across all flight segments.
2. Is it necessary to fix name errors for stopovers too?
Absolutely. Every boarding pass must match your ID. Call +1 (888) 674-4858 for corrections.
3. What documents are needed to change my name?
A government ID, marriage certificate, or court order is needed. Use +1 (888) 674-4858 for instructions.
4. Can I do the name correction online for a connecting flight?
Usually not. Multi-leg reservations require calling +1 (888) 674-4858 for personalized assistance.
5. What happens if my name is wrong at the stopover airport?
You may be denied boarding. Fix it early by calling +1 (888) 674-4858 immediately.
