I'm having a problem going lean right at the 2k mark. Before the 2k mark and after the afr are normal but everytime I hit the 2k mark it leans way out to 18+. It started doing this after installing an aeromotive FPR kit from Driftmotion. The J tube was removed and blocked off with the block off plate from the kit. The pressure was set to 35psi. I am tuning with HKS PFC-FCON, VPC, and GCC. It did not go lean like this before installing the FPR kit. Any ideas on what I should look for or missed something?
