what goes bad?
sbnryn15
monroe nc
ok i just got a mkIII na and it wont start... so i just wanted to know what are the things that go bad the most... so i can replace them. If you can tell me, then please do.
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
What goes bad...like all cars anything and everything can go bad...
To answer your question properly symptoms would be nice. When you turn the key does it try to start, does it just make a click noise, or no noise at all? Has the car been sitting for a while?
No start could be battery discharged/deadcell/not grounded, bad starter, bad coil, bad plugs, bad wires, bad cap, bad rotor, ect, ect, ect....more info required to diagnose problem.
AJ'S 88NA
2,419
Florida
sbnryn15 said:
dont worry man i already filled the blinker fluid...... but yeah it trys to start but it just wont turn over
How would it try to start but won't turn over???If it's turning over then the motor is cranking? By not turning over are you saying it's cranking but not firing?
