What does the vin tell you?
terror
Antibliss
Jun 13, 2008
242
Alaska
im trying to buy a car in another state and im trying to find out if it has an Lsd or not he gave me vin #JT2MA71NXL0139938. can you tell if it hasan lsd via vin# and what else can you tell from the vin #. thanks
JimR
Canada
Using the Toyota EPC (Electronic Parts Catalog) along with the info you have posted, here is what I can tell you:
Model: MA70L-BJMVZA
Engine: 7MGTE
Transmission: R154 manual
Steering: PPS (Progressive power steering)
Date of manufacture: September, 1989
Differential: Limited slip. 3.73 final drive.
Destination market: USA
Using the VIN, and some basic knowledge of the car, you can determine exactly what parts are on your car. The two other pieces of info I needed to confirm the exact car was if it was manual or automatic, and built for the US or Canada.
Jeff Lange
Administrator
4,927
19
Sunnyvale, CA
jefflange.ca
In addition to Jim's post:
USA model, 5-speed, cloth grey interior, 3E5 red, has ABS, power seats, and California emissions package.
That being said, all Turbos have LSD, and since it's an 89+, all of those have PPS as well, they all have 3.73:1 rear ends too.
Good luck with the car!
Jeff
(A USA dealer may be able to get you even more information regarding the car that I cannot get here in Canada. Namely a build sheet information printout).
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
terror;1120692 said:
thanks alot guys also.... what does the california emissions package consist of?
2 Cats instead of 1 and a special little green sticker under the hood that says CA smog equipped.
More restriction if you ask me.
By the way Ca accepts non-ca smog cars also!
terror
Antibliss
Jun 13, 2008
242
Alaska
well i live in vegas soo that secind cat is coming off, where is it located?
terror
Antibliss
Jun 13, 2008
242
Alaska
MKIIINA;1121414 said:
the ecu is different also for ca emissions... ask me how i know....
hahaha tell me! Is it different in the way that it hinders performance or what?
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
Wrong.
Every Supra 7MGTE had 2 cats. Even the JDM ones. ;)
Only difference i've seen about the california ECU is a sensor for EGR Temp or was that an 89+ thing? :dunno:
No real performance difference at WOT. :D
Edit: Wiring Harnesses are the Same for Cali and Other US cars. So it must run a little cleaner at cruise. :dunno:
JimR
Canada
California models have a secondary oxygen sensor after the catalytic converters. See EPC figure 8401.
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
You can contact Toyota or the National Auto Thrft Bureau, they know where the location of the line sheet or production sheets are within your vehicle, when cars finished assembly the order sheets used to determine what pieces were put on the vehicle were hidden within the vehicle for identification in the event the car was stolen, contains all parts on your car with numbers and your cars VIN
Evilempire1.3JZ-GTE
Jun 22, 2006
1,382
SoCal
Zumtizzle;1121485 said:
Wrong.
sorry about the mix up the 7MGTE are about the same just 1 egt sensor is added fo CA, the 7MGE can be in two completely diffrent setups but I never had the 7MGTE I skipped over that one.
1 extra cat is added and of course 1 more O2 +EGT sensor. kind of like OBDII
