What does fuel cut feel like
Zrain25
639
Pelham,New Hampshire
I was driving my buddy was behind me riding my ass I reduced to 3rd gunned it and once I hit higher rpms the car felt like it died picked back up died picked back up died. Then I laid off the gas and it was good the cel light went on then when off.
It feelt like it was running low on gas. It was weird
I have 3 in downpipe and elbow.
Exhaust
Intake
Fmic and hard
I have hit 11psi watching boost gauge but I never went high rpms like this time
Is that fuel cut..
jetjock
creepy-ass cracka
9,439
Zrain25;1926952 said:
It feelt like it was running low on gas...
Must be why it's called fuel cut huh?
Fuel cut shuts off the injectors. Loss of ECU power shuts off the injectors. Same difference.
Code 11 masks all other codes. If you have code 11 you have bigger problems than fuel cut.
Zrain25
639
Well the code 11 might be old. It has issues idling for a whole but it's been running fine for a while il check it out and clear the codes.
Will fuel cut cause a code.
Zrain25
639
Then why would it not show code 34
If it hit fuel cut then it should show it.
I'm gunna check out the code 11 like I said I never hit it fuel cut before. But I did just install a 3in turbo elbow 2 days ago
