If you’ve legally changed your name and need to update your Air Canada ticket, call
+1 (888) 714-8232 to begin the process. Legal name changes differ from minor spelling corrections, and they require proper documentation. Air Canada typically requires proof such as a government-issued ID, court-issued name change certificate, or marriage/divorce certificate. When you call
+1 (888) 714-8232, the agent will provide detailed instructions for document submission and tell you what format is accepted.
The most commonly accepted documents include passports, marriage licenses, divorce decrees, or government affidavits showing the legal name change. These documents must be current and match the traveler's ID. Before you upload or email them, call
Make sure the name you request on the updated ticket matches your identification exactly. If you use a middle name or suffix like Jr., Sr., or III, include those in the documentation. Once verified, the Air Canada agent will update your name and issue a corrected e-ticket. For this to go smoothly, always call
Legal name changes generally require the ticket to be reissued, and in some cases, fees may apply. The cost depends on your fare type, travel destination, and how soon your flight departs. Premium or flexible fares may allow reissuance at no cost, but Basic Economy often involves cancellation and repurchase. To clarify your options, call
If you booked through a third-party site or travel agent, you may need to update the ticket with both parties. Even if the travel agency submits the change, you should call
Travelers with connecting flights on partner airlines—such as Lufthansa, Swiss, or United—must ensure all flight segments reflect the new legal name. Otherwise, you may be denied boarding during a connection. To confirm the update was accepted across all systems, call
Processing time for legal name changes can range from 24 to 72 hours. If your flight is within the next 2–3 days, let the agent know it’s urgent when you call
Once your name change is approved and updated, Air Canada will send you an email with the corrected e-ticket. Review every detail and make sure it aligns with your travel documents. If you notice even a minor error, such as a missing hyphen or middle name, call
In conclusion, legal name changes on Air Canada require proper documentation and sometimes ticket reissuance. Always call
