What clutch to get for my 7M
8T7supra
78
New York
I am looking for a new clutch for my 7M, I took my car to get tuned last May and my current clutch a clucth master stage 2 gave out at 14 psi at 450WHP. Jeff Evans form Evans tuning who tuned my car said if i turn the boost up to 25-30 psi I should be able to break 600WHP no problem. I am now looking for a new clutch that can handle the power. this car is going to be driven mostly on the street so I am thinking of using a SPEC twin disc kit ss trim. I was wondering if anyone else is using this clutch or knew anyone who is or if their is another clutch that would be street-able in the same price range about $1600-$1800?
8T7supra
78
New York
the spec stage 3 clutch only holds 520ft lbs and that at the crank i plan an making more than that at the wheel. the clutch i have now i rated for 500ft lbs at the crank and it slipped at 410 wheel tq.
Devin LeBlanc
1,830
Las Vegas NV.
ACT Extreme pressure plate with a un sprung 6 puck. I daily drove it, its not that bad if your not a little girl. I made 580 ft lbs of torque and 600whp on 30 psi and it held it no problem. I have it for sale if your interested.
Its rated at 700HP 632ft lbs of torque
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Okay, I laughed. Is this the place where I mention that on the same setup (ACT Stage 3+) I showed my 14 year old daughter (Who, by the way, might weigh in at 80 lbs) what a real clutch should feel like when it engages? FWIW, she had it figured out in a couple of minutes and was able to get the car going with neither clutch chatter nor squeaking of the tires.
