whare to buy thin net cable for knock sensors
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
ok... well Im going to try... so i know when the wireing is bad the ecu retards the timing and rods power but if you actually have a knock and the wires are good will it do the same? i only ask because i have a very small knock but i know the wireing it bad because the code said oper cirket so it thinks there not connected.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,281
71
Atlanta
:werd: :withstupi :word8kn:
You might have... that other kind of knock...
And yes, you can use coax cable. I did on mine.
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
I went to a local specialty electronics store and they had huge reels of the stuff... got about 20 ft of it for like 4 dollars, and some heat shrink tubing stuff and some 14 gauge wire to do my ground wires.. all total came to about $10... try and find a specialty electronics place, usually for tradespeople... they should have everything you need (aside from the ks connector from toyota)
