Whacked Timing D:
Max Vador
46
chicago
new TB with TPS and TPS harness plug thanks to Moy. idle at 700. rewiring knock sensor then timing adjusted tomorrow
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
86.5ny;1586654 said:
...amen JJ, my motor was stuck at 5 deg BTDC and would NOT change because of the faulty TPS..
Yeah, as I've pointed out before when diag mode is entered the TCCS sets idle speed and disables ESA. Those things can't occur if IDL is open. It's why timing should not be attempted without first verifying a TPS code 51 is *not* present with the throttle closed.
For those who remember it's no different than the procedure used on carbed engines with vacuum advance where idle speed had to be set and advance defeated. The reasons behind this haven't changed. Now the TCCS simply does it for you.
86.5ny
OC, NY
at the time i knew about the code 51 and tried every way to get the TPS to respond properly. Any meter reading of the IDL - E2 and VC - E2 was perfectly fine, but could not get good readings for any VTA. with the new TB and TPS (also used a new TPS connector from the harness that came with my motor) I did not adjust the TPS as per TSRM because its a pain in the ass detecting deflection on a digital meter. I just measured the VTA at fully closed throttle and the IDL at whatever mm my thickness gauge gives between 0.4-0.5mm. For the first time I've had no codes and its a joyous occasion.
good luck to you max, i havent had to rewire the knock sensor but my guess is that its a sealed-insulated wire according to the TCCS wiring diagram is nearly identical to the n/a o2 sensor wire.
Max Vador
46
chicago
Yeah it's just a single insulated wire from the knock to the ecu. Being a single hanging wire it's prone to crack or loosen. Hopefully it goes painless.
