7M-GTE 89 5spd
So the reason why the Supra did not start was the CPS. We timed it and also followed the book on the CPS setting and the car starts fine and it used to idle fine, The cars BDC is at 13, is that right for the 7m-gte? The car still bogged after 3K rpm. I put in new NGK IRIDIUM IX plugs (now it doesn't idle fine) but I could have possibly gotten the order wrong but isn't it supposed to be 1,6,3,4,2,5? So I let the car warm up and I checked the codes, I got code number 34 and 51. Maybe becuase I am running more boost due to the testpipe and downpipe I blew the lower ic hose and I got massive boost leak? The car has ruff idle. It has no power, and the car jerks really bad. Only reason I am thinking its the lower ic pipes is because I fixed a powersteering leak and it used to leak on the piping also the cps used to leak on it too. I checked cynus for the fireing order but i am confused. Heres the link http://www.cygnusx1.net/Supra/TechTips/statistics.aspx Fuel system and engine data both give me a grouping for the plugs and I am not sure which one is correct.
Thanks guys
-Steve Z
p.s. hope this is better than my last threads
Thanks guys
-Steve Z
