Well im killing the POS idea
JStoked
646
Edmond, Oklahoma, United States
So i have decided to put my 7mgte 5 speed in my 86 mx73 cressida. till i can afford to do the 1uz swap.So what do i need off the supra to make the swap for the 7gte? what we have. The tranny,the motor, ecu, clutch peddle, ignitior , the clips for the ecu that run the dash.the whole wiring harness for the engine, clutch master cylinder, drive shaft, fuel pump. What am i missing? i know this is a supra forum but i am so ready to make a sleeper that the kiddios can ride in.
PRetty sure all cressy have front sump oil pan. Meaning you need the pump too. An upgrade would also be in order or atleast i think it should be since the ge pump doesnt flow as much.
I would think it does and same with the oil pump. But might either want to block off the squirters or modify it. Shim it not matter what.
