does any1 kno wat gauge the steel is for the supras bc i have to weld sum rot holes shut today n dont want to use cheap grade crap
planemos;1791197 said:If you put a piece of aluminum behind the hole while you are welding it will help you fill the hole easier and it doesn't stick to the aluminum so it's easy to pull off after.
planemos;1791197 said:If you put a piece of aluminum behind the hole ... and it doesn't stick to the aluminum so it's easy to pull off after.
