weirdest thing happened today
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
Hondas do that when their IACV is clogged. Could also be a pirate air issue, or an airflow sensor wire losing contact. What code did it have before you reset the ecu? That and what have you done to it lately?
Devin LeBlanc
1,830
Las Vegas NV.
Done nothing to it and there are no codes present.. Today I started replacing things and it stopped doing it when I replaced the fuel pump resistor.. It has been fine all day now, I was cruising down the street and my check engine light came on with code 24 (Air intake temp sensor open or short circuit) Checked everything and everything tested good cleared the code and nothing has popped up at all after driving it a good 15 miles.
