weird temp. reading
chris1039
80
tucson, arizona
for the last few days i have noticed my temperature gauge was giving me ome weird readings.
when i accelerate over 4k rpm the temperature gauge starts to climb. if i take it to 6500 it goes past the red zone. but as soon as i let off the gauge goes right back to normal.
my engine doesn't seem to be overheating. but the radiator hose is super tight when it is warm.
any ideas.
NewWestSupras
SoupLvr
Mar 1, 2006
611
White Rock
Any coolant loss? I'd pressure test the system, and check for codes first. Any ideas on how old the thermostat is? I'd make sure your water pump is 100% as well. gl.
TooGoode
rediculous DD
Mar 1, 2007
549
Chandler, Arizona
any ideas.
stop looking at the boost gauge.......haha jk....
chris1039
80
tucson, arizona
lol it moves just as fast as the boost gauge. and no coolant loss or milkshake oil and the engine never feels like its hot. the thermostat is new.
the guage moves so fast im thinking it the sensor or gauge screwing up.
oh yeah im only throwing code 11
cuel
1,536
Baytown, Texas
You're probably grounding out the sensor wire somewhere. I'd check the harness from the connector back for broken or worn insulation on the individual wires.
If it grounds out it will peg hot, not gradually increase...
If the upper radiator hose is that hard, you might have other issues...
jdub
Feb 10, 2006
10,730
Valley of the Sun
"Only code 11"? ECU power interruption...the one that overrides and masks all other codes?
It doesn't have anything to do with your temp gauge problem, but that is one code that I would not be so nonchalant about.
