Weird start issue
GuNDeZZZ
Was dgilman360
Sep 28, 2006
619
Lakeland Florida
Alright i left work at 7pm got to the girlfriends house with no problems i got there around 730 or so my car sat locked for 2 hrs then i went to go start it to go to walmart and all i got was a starter click.... no turn over or nething
so i disconnected the batt and went inside to get ahold of jayson or someone to help out or something it sat for like 20 mins
i went back outside and hooked the batt up and it cranked right up...
im just worried my ALT is going on me and my supra is my DD now so i cant have that happening at work or something
let me know what you think.....
:1zhelp:
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
so it is just battery drain? mine has been doing that the pastcouple of weeks and i gave up. do you have a voltmeter?
mk3supra
231
Decatur, IL
www.supramania.com
starter bendix is goin out, mine did the same thing and continued to get worse untill it would take me up to 15 min. to get the car to finally crank. Got the starter rebuilt for around $30 and never had a problem since.
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
Solenoid on you're starter... ether its gummed up or its simply just to dirty (its basically sparks every time you switch it over (its like a see saw.. with a small magnet moving it) so a peace of carbon might be in the middle. If you jump start it it could have enough juice to jump the gap that you're new battery is lacking. Or you could also try banging on it.. there is a little set of teeth that come out onto the fly wheel and that might of got stuck too... if its manual just leave it in gear and push it to move the fly wheel.
To fix you're starter just take it apart (solenoid only) and clean the fucker, that is if it was working strong before.
If it makes a ticking noise on the passengers side\/\/\/
Its you're alarm, try reseting it by unlocking the doors with the key.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,280
69
Atlanta
Werd- Take the starter out, clean the solenoid contacts with some emory cloth/sandpaper, do the same to the plunger, clean out any particles, and lube the plunger shaft. OR, you can completely replace the contacts for about $14.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Easy tigers.....
Try this first.
There is the starter signal wire that comes out the back of the starter. 50% or more of the time, this is the "Dead starter, it just clicks, I hear nothing" problem.
Take the wire with connector off the back of the starter, and clean.
GuNDeZZZ
Was dgilman360
Sep 28, 2006
619
Lakeland Florida
MDCmotorsports said:
Easy tigers.....
Try this first.
ill try that tomorrow
its weird i disconnect mt battery wait for like a min or so and try again and it cranks....
but it happened again today sucks ass
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
Easy tigers.....
Try this first.
O O O O ... that one too! who needs a splash shield under the car right! come on who's with me!
O why O why do supra's have electrical problems?
