weird rattle?
jrot
195
knob noster, MO
in the morning or on cold starts i get this odd raspy rattle...only last a second but i can figure where its coming from....it sounds like a leaf is being chopped up in my fan only really close to my fire wall on the engine side...any thoughts? i cant see anything that would cause it....
te72
Classifieds Moderator
6,624
9
WHYoming
Heh, you'll drive yourself nuts trying to track down every little noise these cars can make man. Common sounds heard upon startup of our cars include the 'waterfall' (do a search, you'll see dozens if not hundreds of threads), exhaust leaks, rods knocking (sadly), and a distinct little sound I like to call "awesomeness". Maybe that last one isn't heard on every Supra, but I know it is on mine. :)
te72
6,624
9
WHYoming
Awesomeness is that sound that you hear when you start up your car and realize that for all the hard work you've put into your car, it's ALL been worth it, knowing you're likely going to be in the coolest thing you see on your way to work. :)
Far as your noise issue goes, there are some noises that are problems, and some noises that really aren't. Is it persistent? Probably should look into it a bit, do some homework. Does it go away shortly after startup? Might not be a big deal then. However, there are some things that WILL seem out of place, and it's up to you to learn your car's quirks.
jrot
195
knob noster, MO
well its a new sound so thats why i thought it worth a new thread....it doesnt persist at all no exageration it probly last 1sec tops....i have had the car a year and know the quarks pretty well but have not had it through a cold winter....just moved to MO from NM....so new quirks make me nervous
te72
6,624
9
WHYoming
Eh, all I can say is keep an eye on your fluid levels at all times, no matter what engine you're running, although doubly so if 7m.
