Some background:
Engine was rebuilt three years ago and along with the upgraded 57-trim that went in, I also installed an AEM Truboost. Anytime I was in 0 to low boost, there would be a pulsing noise, sensation as if the wastegate was opening and closing repeatedly. I knew it was related to the truboost, because when I plumbed the wastegate back to stock, it went away but just didn't boost as high. Now this didn't bother me too much because a simple solution to the surging/pulsing was to simply give it more throttle and up the boost and it would go away. However due to some newb idiocy (didn't prime the motor long enough to fully oil the new turbo), I had to rebuild the turbo until a new stock one could be found.
I have now found the new one and am just about to finish rebuilding it as well. As such I want to try and get rid of all issues to make this turbo last longer than the one year my upgraded one did. Has anyone else had experience with setting up the Truboost and having to deal with what feels like wastegate pulsing at low boost?
Another probable issue is that I was running a 57 trim turbo on stock ignition/fuel and air. Granted that ignition is now upgraded to a COP setup and fuel has an AEM pump with AFPR but still stock injectors. Stock AFM and housing. I have been told that it's OK to run a 57 trim with this set up but I want to confirm that as well. If having an upgraded turbo with stock fuel/ignition and air is indeed OK, then I might consider putting the upgraded compressor, compressor housing, shaft and exhaust housing on the newer in spec center housing (which is what went bad on the old turbo, bearing surfaces were worn way out of spec and scored from running dry). If it's not such a great idea, then I'll be OK with just using the completely stock turbo to hold me over until my manual swap/standalone install is complete.
Thanks for your time, looking forward to some educated input =D
