been having problems with my 90 7mge supra...no fuel so no start...i ran a ecu diagnostic test and got a code 22..so my question is if that runs back to the ecu will it stop the the car from starting?
I thought your problem was the fuel pump not running? If so code 22 isn't involved. On the other hand if the fuel pump *is* working a 22 will make the engine fussy to start when cold...
well other than that i dont know what else to try, i am going to replace the sensor cause its broken anyway but other than the 22 all else is clear....any ideas...ill keep u posted b/c the same thing happened to my turbo mk3 supra too.
