water temp gauge not reading
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I just noticed the other day that my water temp gauge was not reading at all, the needle just sits there. I've been wondering if the gauge is broken, if there is something wrong with my thermostat, if I have a bad connection somewhere, etc. Can anyone help me?
BTW, I have done searches on here for this and the results of those searches have, for the most part, been inconclusive.
Thanks for your time
-Chris
AJ'S 88NA
2,419
Florida
Check the wire that goes to the sensor on the thermostat housing it was making a bad connection on mine and just squeezed it closed a little.
isnms
United States of America
Oklahoma
i80.photobucket.com
and just in case you're not sure which one it is:
Chaos_Performance
Ohio and Mass
it may just be the vacuum hose there are two on the top of the top radiator hose inlet into the engine the top line controls it i broke mine when installing my k&n and it doesnt work now no big deal as long as u know where ur car normally runs then ur good.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Didn't know, sorry. Do I need to replace the gauge or is there a loose/bad connection somewhere or ... ? I don't know anything about the electrical aspects of my engine, but I'm learning as I go and want to learn more. Any insight would be helpful :icon_bigg
Thanks
Who
Does that same rule apply to a gas guage that doesn't work?
In my humble opinion if you could do without a gauge in the 7m it would not be the temp guage
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I think I found the problem. There is a a wire disconnected from a (brown I think) clip that's attached to the therm. I'll try to get a picture of what I'm talking about up later for clarification
