water puddle in my passenger side floor
streetdreamz
YumaAz/KingcityCA/L.A Ca
this morining i woke up and there was a puddle of water in my front passenger seat carpet... i know it has something to do with the a/c unit in back of the glove box but when i took it out i couldnt find where its leaking from! :1zhelp:
streetdreamz
would that also be the prob why my a/c isnt coming out as cold as it was because before that it was cold and now its not as cold and i added coolent already to the a/c compressor about a month ago?
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Over charge it? spring a leak in the evaporator, clogged climate box drain tube? blown heater core.
Most likely if it was your heater core you would be adding a lot of water, AC system leak, recharge the AC alot.
