Water neck sensors thread pitch for plugs
Zrain25
639
Pelham,New Hampshire
I'm deleting most of the sensors except for the ecu temp gauge any one know where I can fine the thread pitch for the other sensor ports so I can plug them
SideWinderGX
733
thesupragod
183
Mount Vernon, Ohio
Fastenal
There are plenty around here, and have a website if there are not any close to you. You can also try the little mom and pop hardware stores, big box stores usually dont carry this size, but the small places just might.
Bmettie
188
Florida
Zrain25;2071405 said:
Ok so I found the 3/8 pretty easily I'm ha wing trouble finding a m12 X 1.25 plug any one know a good place to find them
http://www.hydraulicsdirect.com/BSPT_Hollow_Head_Plug_hydraulic_fittings_p/9030tcsp.htm?1=1&CartID=0
http://www.hydraulicsdirect.com/SearchResults.asp?Search=m12+plug&go.x=0&go.y=0
http://www.hydraulicsdirect.com/SearchResults.asp?Search=m16+plug&go.x=0&go.y=0
SideWinderGX;2071472 said:
Report back with what size actually fits and doesn't leak. m12 seems too small, and I have my notes saying m16x1.5 fit.
I have 3x 3/8 BSPT plugs in the t-stat housing now and they don't leak. And I was mistaken m12x1.25 is the ECU coolant temp sensor, m16x1.5 is the cold start timer switch(edited post), and the coolant line to the turbo is 1/4 BSPT
Bmettie
188
Florida
SideWinderGX;2071537 said:
Ahh, I have an m16x1.5 in the cold start timer switch, a/c fan switch and aux fan switch sensors, they are all the same.
Is the BVSV 3/8 BSPT or is it some other vague thread?
yup, 3/8 BSPT
