Water jacket in back of head?
TEMPEST
We're a work in Progress
Jul 29, 2006
27
New Orleans
I'm doing a BHG rebuild and noticed that the water jacket in the rear of my head is...not there. The block has an outlet, the gasket as well. In the head there is just a corroded aluminum area where the jacket should be. Anyone know why?
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
Nick M said:
How exactly do you notice that something is not there? Pic?
nick, on the head, it is just a flat surface, but the stock headgasket has the copper and gasket hole for it at the back. i could go out and take a pic of my block as well, because on the block there is a gaping hole that has coolant running through it but just gets blocked off from the head. if you drill it out, there will be more coolant going through the back of the head and recirculating it more so that even piston number 6 will get better cooling, and not just the head.
its really weird why toyota decided at last minute to not include the hole in the head... maybe the real 6m's have had that coolant passage because from what i understand its the same block.
But anyway for the drawback, all i can see is that you will lose a bit of heat going into the heater core because the pipe that directly goes over the location of the hidden passage, but for most of us that really isn't an issue...
edit. does anyone want me to take pictures? lol.
edit 2:
mkIIIman089
Ohio
Thats very back yard engineering. I have to imagine they blocked it off to promote flow a certain way, and drilling it out will make it cool worse then it did to begin with.
Mr.PFloyd
Jun 22, 2005
3,964
Nick M said:
That is called an all new head on not all new block.
? i don't get it. and that may be crude, but how do you think machine shops do it? anyway, toyota did a lot of weird stuff with this motor, and looking through the coolant flow chart, this would make coolant flow better.
-Thomas
TEMPEST
Jul 29, 2006
27
New Orleans
Well, I'm glad I asked! Just for the record, I'll have to drill the passage out. It's alsmost through the block as it is! The aluminum is just gone with some serious pitting corrosion. Good to know it's not altogether a bad thing. More people should probably be aware to look for this as this head gasket was replaced by the previous owner who probably knew nothing about it. Oh, at less than 20k ago on a motor with less than 100k presently. I'll be hand machining the head myself, trust no-one!
Oct 11, 2005
3,819
21
Thousand Oaks, CA
I would suggest that unless you actually model the coolant flow with a 3D FEM fluid flow simulator (like Toyota did when they designed it) you should leave it alone because they did it for a reason. Note also that the intake side block coolant ports are partially blocked off by the head gasket holes (look at the pic above). Again, done presumably to balance coolant flow to get more flowing on the hotter exhaust side.
There is a finite volume of coolant from the pump, and you need to balance the flow so that hot spots get enough and cool spots don't get too much. If you unblock the port, some other part is now getting less coolant. Screw around with it a your peril.
Kai
That Limey Bastard
There was something similar to this on the 2.8litre Cologne V6 engine ford put out over here - there were gasket passages for the water, but not in the head. Drilling two holes 1.5cm into the head solved a massive problem with overheating, as the valves were in an odd config due to the siamesed exhaust passages.
Head went something like this
I---E---I---E-*-E---I
* is where you drilled the two cooling passages.
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
when a 7m blows a head gasket it tends to be the #6 cylinder this is why. it was put there to keep the egr cavity a certain temp I drilled mine out and have had no problems and I checked points on my block with a laser temp gauge and have only seen good results from this. Truthfully I think I should have made the wholes I drilled bigger
