Wastegates
Torque
255
In your home
OK guys I have a turbo, about to buy the Drewgo manifold and downpipe. Now my question is what size wastegate do you guys recommend, there are so many sizes. The turbo I have is a PT63. any info will be greatly appreciated.
I have a Tial 44mm wastegate and it's always worked perfectly for me. I used to have a gt35r and now I have the pt67. I still have the same wastegate though.
jdub
Feb 10, 2006
10,730
Valley of the Sun
On a 1J? (that's what it says in your profile)
Moved to Other Engine Tech where it belongs...please post in the correct section in the future.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
if your aiming for alot of power i would get a bigger one like atleast 44mm and up. i have a 50mm and its been working good
Torque
255
In your home
My fault, wont happen again. I'm not really trying to make any serious power. I just want to get rid of these smoking little twins. Bottom line I just want a car that runs good and I wont be afraid to drive it:icon_bigg
It all depends on how much boost you're trying to run V's Turbine AR but the 44mm is a good compromise and works well.
The Tial is faultless and I've run it from 5psi to 30psi.
