Wastegate?
BasicMinusBA
Awesome Member
Mar 30, 2006
45
East Lyme, Connecticut
Alright, I thought i had a boost leak i changed pretty much all my intercooler piping, and tried changing the blow off valve, and still nothing, im looking for what might cause me to only boost 3 psi when i normally boost 14, how can i check to see if my wastegate is malfuntioning?
MDCmotorsports
Indy 500
www.MDCmotorsports.com
You'll need to take off the eblow so you can see the wastegate flapper door.
Hook up a 10-20psi compressed air source with rubber hose to the wastegate nipple.
Presurize (sp?) the wastegate, and see if the flapper door moves.
Mr. Y
80 miles away from Kremlin
BasicMinusBA
If you were boosting till 14psi, your WG spring should be very hard. I don't think it can be "moved" easily by the hand.
Also check exhaust (turbine) housing for cracks and shaft freeplay. My first Ct-26 died with huge shaftplay and cracked housing... It couldn't produce any boost too...
