walbro high flow fuel pump question
willfish
been here since 2003
Apr 23, 2005
648
Pittsburgh, Pa.
I have my tank down, , the old pump is off, old pump has (2) blue wires going to the (+) and (1) black wire going to the ( - )
on the new pump.
the wiring harness has (1) red , (1) black
do I splice the black to black ?? and the red to the (2) blues ???
thanks guy's
Will
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
ok, question,
can I hook up the (3) gas lines that mate up to the bracket after the tank is up an bolted down ? is there enough room to do it if the car is jacket up enough ?
or is it easier if the tank is down ?
I think its a deffinately 2 man job .
Will
lagged
1991 1JZ
new rochelle
willfish said:
yea, dropping it is easy, putting it back up is another.....
yeah those straps are a little tricky. the key is to not tighten either of them down, just get the bolts threaded in both of them first, otherwise itll be hard to line it up right with one strap tightend down all the way.
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
my problem , is just to get the tank up enough to I can at least start a bolt on one of those straps......
any tips ?
this shit sux....
again, can I connect the 3 gas lines after the tank is up an the straps are bolted ????
Will
staticpat
Supra Chair!
Birmingham, AL
You can, but its not easy. I tried and never could reach them, but abuddy of mine did it without a problem.
As for the straps. I tried jacking it up in place and starting the bolts but I don't think it worked. I started one side of each strap first. Then I'm pretty sure I just set the tank on my chest and raised it up making sure the filler neck went in right. Then I just held my breath for a long time until I got one started. Not the easiest job. Also I spilled some gas in my eye from the return line :<. Wear safety goggles.
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
i used my knees to push up the tank so the filler neck went into its place and did one strap, used a jack to support the other side and sort of shuffled over and loosly did up the other side. helps when the tank is empty or close to empty.
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
right now its 7:45 am , last night i got frustrated with it an left it where it is, witch was , up an off the ground, but sitting on my little tool box but high enough that the filler neck is in place an the cap screwed on,
I'll give it a go with those straps again alittle later, ,,, I know I'll ge M/F'ing it some more though
Will
