Okay guys I got my swap and cars running pretty good now, but I'm getting code 42 (speed sensor) to my understanding that you need VSS because it actually helps with engine control (turbo control really). I'm thinking a host of my problems is from my speed sensor issue. The speedo's never worked, and I know the mechanical cable is stuck, is there any other way to bypass the VSS?
Or normal operation of the twins without the VSS?
After searching all last night it seems if I go TTC then I won't have to worry about the VSS.
