is this a good place for the vpc temp sensor? sorry 4 the ignorance but im new to this turbo stuff, im just tryin to figure out what the PO did....any advice is welcome, i know my car is old school...:yikes:
thats fine. though should be on the other side as the instructions showed . but if its running ok then leave it, if its running rough, then plug and move it
mine is mouted on the side under the PCV breather between the valve covers
yes. before the throttle body. i dont what the temp of vaccum is when the plate is closed, so i can only imagine its no accurate. almost every car on the market has the temp sensor in the plumbing before the TB. the temp sensor is internal on the stock AFM,
my thottle response is a lil to touchy, its tap gas, spin and go lol
