I was testing my mbc to set my boost at 20 psi but i screw too much and it went 26psi, fuel cut kicked in and after that the car keep stalling. It wont hold idle, throw code 31 and the hz is not reading on the afc. This was just second gear pull to set boost level. any help. bad map sensor? i have hks vpc.
