Voltage problem
87'N/A
83
Auburn, WA
My voltage gauge has been bouncing back and forth from about 13-16. Sometimes it will even spike to over 18. It started happening right after i replaced my alternator so i think that's the problem but just to make sure what other things could be causing this to happen?
p.s. I know it's not a problem with the gauge itself because when the volts go up and down on the gauge the headlights/any lights on the dash will get brighter/dimmer.
8,897
Why did you replace the alternator? Did you put a Fluke on the battery and watch it? How about on the alternator output?
8,897
Fluke makes digitial volt and ohm meters, commonly called multimeters. For diagnostic purposes. Is it a remanufactured alternator from Toyota, or an autozone special? How is the wiring to the alternator?
