My volt gage reads low (has been for 2 years now) and its about time i fix a couple of the small issues with the car. The gage reads at about 12-12.5 volts and drops significantly when the blinkers are used.
It has been reading like that ever since I have had the car. I put in a 1JZ, but I don't know if the problem started then or earlier.
My charging system works just fine, so it must be a bad/dirty ground. Where should I check? any ideas?
