Very Simple Question
Vanish
Calgary, Alberta
This might as well be in the books for "the easiest question"
Bought a 1991 RHD Supra from this guy for about 3,000 CND, I am thinking of replacing the old 7M-GTE which has about 275K for a lower KM one. Will the RHD effect anything while the swap?
I have no clue on anyhting related to RHD, please odn't flame i just want to clear it up :p
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
Re-word your question its not making very much sense but i will answer it the best way i can from what i assume you mean.... are you asking if you will have to change the wire harness or extend it. If so no you dont have too b/c the engines will be the same just make sure you use the right sending units. For example the JDM oil sending(small bullet looking thing) unit is different from the USDM(big round shiny thing) but both will plug up but the guage in the car wont work without the right one but the car will still run just fine you just wont know your oil pressure. Hopefully that answers your question
bountykilla0118
Jul 16, 2005
1,088
Atlanta GA
Vanish said:
Sorry about the wording of the question what i meant to ask was is there any difference between LHD and RHD?
Wtf is your question? B/C the actual answer to the question you asked is Yes there is a differnce between LHD and RHD hmmmmm the steering wheels are in different locaions! A bit of advice make your question as specific as possible not the difference between LHD and RHD ?????? the only difference is the wiring harness b/c the ecu's are in different spots other than that they are the same. So use the harness that goes with your car man .....
