Very odd problem with my 1jz!
Highlex
61
Manitoba
Hey guys, two weeks ago when I was driving home from school my jza70 1jz 5-speed mk3 died, I cranked it over again and it started for 5 seconds, then died. I cranked it over again, ran for 3 seconds, then died. Then I cranked again and it kept cranking.
I opened up my ecu and found a melted capacitor, I sent it away to driftmotion for his ecu repair service, the fixed ecu came back today and I plugged it in, the car started and ran for a two minutes, then died. I cranked it again, ran for one minute, then died.
Im thinking that the ecu was not the problem and the car just ran for two minutes because I let it sit for a full week while waiting for my ecu...
So basically the longer period of time I let the car sit for, the longer it will run / idle for. If I wait a full day before cranking the car over again the car will run for a minute, but if I tried every hour cranking it over it only runs for several seconds.
I took off the gas cap and it de-pressuized as normal... also I can hear the fuel pump running, so thats good.
What do you think it is? Where can I start diagnosing... THANKS!
Highlex
61
Manitoba
Tomorrow at lunch im going to check the codes and see what they say, im also going to hook up a fuel pressure gauge at the fuel rail and see what that reads.
Anyone else got an idea? What are the symptoms of a bad map sensor
te72
Classifieds Moderator
6,616
9
WHYoming
Try holding your gas just a bit when you're starting it up. My ISCV is picky and likes to stick closed sometimes when it's cold, and will do some rather similar things. If it is your ISCV there should be a set screw that you can adjust to the left of the throttle body to keep your throttle cracked just enough for it to idle. You might also check your TPS... Mine was broken (the ceramic on the inside) during shipping.
Highlex
61
Manitoba
All I got was Code 14.
The first part of your advice was right, it did start when I held the gas peddle down abit. The car wouldn't idle untill we adjusted the idle screw and that kept it idling at 1000.
When I took it for a drive it drove good untill I floor'd it. Then it cut out violently like fuel cut at 4500 rpm or so, it cuts out violently everytime and sometimes it will even stall and then the car won't start for a few minutes. Could the fuel pump ecu / relay be to hot and not working? Once it cools down it drives fine untill the peddle is floored and the boost starts to kick in then it cuts out again.
Don't these cars have a 2-speed flowing fuel pump? Could it be that the fuel pump can't kick into higher flow mode?
What is the pressure supposed to be at the fuel rail? How do you force the fuel pump into high flow mode?
Jump B+ FP? What does this do.
Thx
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
your ecu just flat out took a dump on you, code 14 is the ignition circuit, and if aaron repaired the caps, then its just toast
a mine's ecu i had did the same thing to me
Highlex
61
Manitoba
You think so? The car still drives normally though untill I floor it. I think its the fuel pump relay, im not sure where to get a used one in canada other than here.
Its a jza70, 1jz mk3 rhd
te72
6,616
9
WHYoming
Something to check on, spark plug gap. Mine was breaking up under boost around 4000 or so, until I gapped the plugs around .28. Haven't had the problem since. Although I didn't have that code 14 problem, but it never hurts to have properly gapped plugs does it? :)
Highlex
61
Manitoba
Im going to try and read fuel pressure at the rail, what is the fuel pressure supposed to be? Is there a way to test the fuel pressure when the fuel pump is in low-flow mode or high-flow mode?
Highlex
61
Manitoba
JPsToyota;1586848 said:
You are not hitting boost cut, right? Does your CEL light work and does it light up when you get this under boost problem?
My CEL does not come on when I experiance this cut out, but my CEL does work. I have code 14. Im thinking the fuel pump ecu or ignitor could be the problem?
The car will not idle unless the idle is set higher (above 700rpm) if it reaches 500rpm, it will die. Could it be the fuel pump?
Highlex
61
Manitoba
92TealSupra;1587467 said:
Sounds like your ECU could still have an issue?? Any friends with a spare?
Possible...
Im going to have to ask around, I don't think anyone has a 1jz ecu around here... Manitoba Sucks :(
Highlex
61
Manitoba
How can I test my MAP sensor? Do you think this could be my issue.
Sometimes the car does not start without giving it some throttle, it the idle gets to low (600) it will die... and if I put the peddle to the floor and the revs start to climb it will cut out and die, and wont start again untill it cools down.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i have a similar problem that i never figured out... wheres the fuel pump relay and do you have a wideband? when your car cuts out is your car going lean 15+ air fuel raitos? to test your map you can try unplugging it while the car is running to see if that makes a difference
