Valve shims
Zrain25
639
Pelham,New Hampshire
I measured the head came out to 115.7 mm stock is 116. Gunna get as little shaved off as possible. I have no idea how much the block has been decked but I'm most likely gunna have to go with a 2mm gasket.
Any one know the specs on the crank journals and rod journals
87suprat
salem
Hey! I have tons of shims probably enough to do 20 heads. I can send ya some? Ill check on here tomorrow see if you replie
87suprat
salem
Hey ment to tell ya Toyota tercels mr2 us the same shims, go to the junkyard rob some motors. That's what I did now I have everyone Ill ever need
