Vacum hose routing
1jz Jalopi
Guest
Yo CK,
AIM me and ill help you out with the vaccuum wiring, im pretty sure i know where all of it goes.
91Supra313
1,062
Clarksville TN
Ok here is what I did. I purchased a vacuum block from Ebay. Cost me less then $30. It has maybe 6 ports on it?! I ran my AFPR to it's own port on the manifold, and then one of the other large ports on the manifold to the vac block. Then you can run what you want to the block. I am currently using 4 of my six ports. May take a few days to get your vac block in but it is the most simple fix. Plus you will have extra ports for later. Or you can do a simple google search for 2JZGTE vacuum line diagram and it should come up with images like this. I know it is a hard job to do but searching before begging is a must. This took me less time to find on google then it did for anyone to type a reply in here.
http://www.google.com/imgres?imgurl...GpPw8ASLiYDoCg&sqi=2&ved=0CC8Q9QEwAA&dur=2898
