Vaccum line....please identify!
tropical 87t
68
Lake City, FL
Can anyone tell me where this black screw-in connector on the upper intake manifold should be hooked up to? See photo. Thanks.
tropical 87t
68
Lake City, FL
MDCmotorsports said:
Ideal is correct. Also, Im pretty sure the harness just doesn't sit on that hot egr pipe like that.... it'll melt.
Thanks, I'll make sure the harness is repositioned when I put the motor back in. The wiring harness is supposed to run inside the intake manifold and under the throttle body, right?
I'm almost ready to install the motor after a rebuild. MDC...do you know how much knock sensors go for (replacement)? Both of mine cracked and the plug/wire just dangles from the hex/metal part that screws into the block.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Knock sensors from toyota are $100+ new.
Contact Jay Marks toyota (I think they are in texas) for a savings, or ask around on the for sale/wanted boards for a pair of good used ones.
