Using JZ's igniter in 7M-GTE (+)
Status
Not open for further replies.
I<3Supras
Drft What do u mean drft?
Southern, Ca
Well i'll be up in the Rancho Cucamonga area in a few weeks for College so probably I can stop by and if i can afford it and if it works, you can help me do the installation.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I messed around a little more with it today. I checked that I had all the right outputs going to the correct cylinders. Checked for good 12v ignition power. Grounded both units to the origional mounting bracket. Got it to run but it's a bad idle like few coil wires were in the wrong order. I tried several different combinations but no luck. Next step is to look at the inputs with the scope. I have a feeling the voltage pulses are less then 5v and are causing the problems. The 1j coils are actually a little higher impedance then the stock 7m coilpack. I don't think each ignitor should have any problem running 3 of them since I already know one ignitor can run all 6. I'm still confident I can make it work. Stay tuned...
I<3Supras
Southern, Ca
Hehehe Yeah heard it from a song and I thought it was kinda Kool. Well i think its kool :rofl:
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Almost there...
Just waitng on the magic 18 pin dip ic that makes it all come together. :naughty:
I<3Supras
Southern, Ca
Very impressive. Keep up the good work Man. I want to see the pics of the set up on the engine. again Great job and keep us posted.
Pete
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Anyone want to buy a used 7m coilpack and ngk wires?
I don't need them anymore because IT FUCKIN WORKS!!!!!!!!!!!!!!!!!!!!! :aigo: :icon_bigg :love: :naughty: :icon_surp :evil2: :aigo: :naughty: :biglaugh:
I now have two 7m-gte ignitors running a set of 1j coils and it works GOOD!
I have a little better idle, no spark plug wires to mess with and a cleaner engine bay. I really don't care how much power you can make on the 7m coilpack, I wanted a cop setup for the simplicity, if nothing else. Now spark plug changes will be a lot easier too. I have been thinking about putting a plug and play kit together for sale but I want to put a few thousand miles on this to make sure there are no issues. I have already tested it at 18psi on pump gas with no pinging or hesitation at all. It actually seems to be a little bit more responsive. That is all you can expect from an ignition system upgrade, a small difference. And I think I am the first ever to do this without an expensive MSD or HKS adaptor. You can not just parallel two ignitors like I origionally thought. There is a lot more involved then that. I don't want to give away any secrets...
Allan_MA70
1,055
Melbourne, Australia
what an asshole! forums are ment to be a community so above all the bullshit and arguing theres ment to be helping each other not this kind of crap! you are the lowest of the low IMHO
lagged
1991 1JZ
new rochelle
yeah dude you asked people for help and they gave it away, and you wont share with everyone else what you came up with cause you want to make money off of it?
you should pay the people that gave their advice if thats the case....(like that would ever happen)
siman
Lifetime Ban
Murfreesboro, TN
Its his secret. HE IS THE ONE WHO DID IT IT IS HIS DEAL.
If you guys want to make your own, use the resources that are on this thread to your benefit!
I can figure it out if he did. It isnt that hard..
so you guys about STFU. :evil2:
Good going man! Im glad to here it works !
-Jonathan
Status
