Using fuel filter as oil/water seperator?
BLACKCAT
185
BHG
Wondering if there would be any issues in connecting a see through fuel filter in the PCV line just before the throttle body inlet to act as a water/oil seperator on a 7MGE engine?
BLACKCAT
185
BHG
I thought the filter would trap some of the oil & water as the pressure running through it would be fairly small & not enought to force out all the contents?
Only to the point where it runs out of room BC ;)
Then I guess it becomes a filter again and you get nice clean splooge into the intake.
There needs to be some way to drain it on a semi regular basis.
