use this turbo on a 7MGTE?
thechori
supra-deprived
Oct 3, 2006
567
houston
hey i was cruising thru a 240sx website and found this rebuilt turbo for sale,
"$450 rebuilt Garrett t3/t4 w/ZERO miles or run hours"
would this be able to bolt right up to a 7MGTE t3/4 manifold? and since it was in a 240sx forum i thought it was probably made for an sr20det, meaning i could probably keep my stock fuel setup too, or am i missing something
i searched for a thread that would kinda explain what the a/r's meant but i couldn't find it ::dunce::
spoolint78
Representing T.O
T.O
pretty small.
find out more specs, like the intake wheel size, inducer exducer etc. Then we should be able to give you more insight on it.
but so far, it seems small
thechori
supra-deprived
Oct 3, 2006
567
houston
MDCmotorsports said:
No.
That comp wheel is almost as small as a stocker.....
Appears to be a O trim turbine.
well i was looking for something similar to a CT26 because i wanted to stick with my stock fuel/air setup. i was just wondering since it was a T3/T4 wouldn't it bolt up to the exhaust manifolds that we use for our T3/T4 turbos?
SevenMKIII
No more Supra no more fun
Jan 13, 2007
474
Central IL
If you want something similar to the CT26, and want to spend that much, why not just do a small upgrade to yours? Almost the same costwise, and could be done by a vendor on here.
ninja edit: and will bolt on, unlike that turbo which would require a manifold, downpipe, wastegate, new oil and/or water lines, and other mods. Not a $450 deal you see it as
thechori
supra-deprived
Oct 3, 2006
567
houston
true true, thanks for bringing those things up. i just saw that $450 turbo vs. a $600+ upgraded/rebuilt ct26
this is now out the window
