URGH 1jz
OneJoeZee
Retired Post Whore
aboard the Argama
SuperSupraKid said:
sorry, i havent really started my car lately, ill have to get back to you guys on this one.
I'm not talking about lately. I'm talking about before. Surely when your car was overheating, you lifted the hood to inspect things.
Did you notice the fan was on low speed? If the fan was not running on the high setting, you would know.
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
foreverpsycotic said:
1jz broke. time to go 7m
hahaha...i never thought i'd hear that one.
sorry to hear you're having troubles with your car. again? didnt you just recently blow your twins? so this would be set #2?
JASONA70
nomnomnom
Oct 27, 2006
743
socal
lol yes set #2 and the fan seems like its on LOW all the time. ill go outside and kind of rev the engine a little and see what happens, orill go for a drive later on. ct12a ftl, my second set. it was a bitch taking off the 1st set and now i have to deal with the 2nd one. im probably going single.
OneJoeZee
Retired Post Whore
aboard the Argama
If your fan has been blowing on low this whole time, it's no wonder your turbos are dead. You've been running hot ass coolant through them.
Maybe they were fine when you got them but you killed them already in short time.
If your fan hasn't been running at high speed at all, you're lucky your engine isn't toast.
Going single isn't going to help you if you can't fix your cooling system.
Fix your car. Worry about upgrading later. Would you rather kill another set of 200 dollar turbos or kill a 1000 dollar single?
JASONA70
nomnomnom
Oct 27, 2006
743
socal
ok so i went and revved the engine and it seemed like the fan was going pretty fast. i cant tell if its on LOW or HIGH because i never really payed much attention to it in the first place. how can i tell if the hydraulic fan is failing? and btw how does it fail? the only thing i know is the fluid pumps into the engine and it pumps back into the fan making it moves, no electronics involved?
OneJoeZee
Retired Post Whore
aboard the Argama
There are electronics involved. How do you think the car uses the fan's high and low setting? :) There is an ECU for the fan.
Unplug the solenoid connector to see if the fan is working. You'll know it. The difference between high and low is very audible. So is the amount of air you can feel being moved.
Don't worry about going single right now. Worry about the cooling system.
OneJoeZee
Retired Post Whore
aboard the Argama
The fan connector is grey. It's coming off the pump.
Unplugging the connector should result in a noticeable drop in fan speed. The fan is very audible. If you unplug the connector, the fan does basically dead quiet.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
ive always thought the fan ecu was the green top connector? =X i kind of spliced into the grey connector because i thought it was old water temp sensor!! i used it for my water temp gauge.. :nono: jdm noob yo
OneJoeZee
Retired Post Whore
aboard the Argama
The fan ECU is behind the glove box. Unless you put it elsewhere during the swap.
The fan ECU connector is not what I'm referring to. I'm talking about the solenoid connector. Are you sure that one's plugged in? The fan should still function without the ECU. IIRC, it just runs on high fulltime if that was the case.
I wouldn't drive the car anymore until your fan issure is solved if I were you.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
the video is 1/2 done uploaded you can see clearly if the fan is functionally correctly or not. if all else fails dual electric fans ftw. ive heard a lot of bad and good things from electric fans.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
upgradedsupra said:
:3d_frown:
Sorry to hear that bud
Duane
im pretty sure its not a BHG ill do a compression test when i come around to it.
im busy with school right now so i cant really work on my car full time like i used to.
OneJoeZee
Retired Post Whore
aboard the Argama
SuperSupraKid said:
ya it was relocated somewhere else. i cant seem to find the fan ecu at all.
I don't know where else someone would put it... That would be too much effort. The connector for the fan ECU is at the end of the harness with the rest of the engine ECU connectors.
BTW, don't ditch your hydro fan for E fans just yet.
And if you really were going to rip it out, just use a 2J clutch fan.
