upgrade IC to fit stock piping?
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
well i found that my coolant leak wasnt from my rad, its form my IC :(. Now i need a IC to replace it. Which one would od best to fit stock location adn piping? is stock my best option as well?
shaeff
Kurt is FTMFW x2!!!!
11
Around
there shouldnt be any coolant leaking from your intercooler... chances are that your coolant resivour spit coolant out onto your intercooler, making it appear that your intercooler is the culprit. the only thing that should be in your intercooler is air.
-shaeff
Mr.PFloyd
Jun 22, 2005
3,964
-shaeff
really? hmm that maybe the problem. im gonna go take a picture now.
shaeff
11
Around
yeah man, do it up. not unless you have an air/water IC, which, chances are, you dont. you'd probably know if you did. i'm betting it's your coolant resivour. the next step would be to figure out why your coolant system is pressurizing!!! (possible BHG)
-shaeff
Mr.PFloyd
Jun 22, 2005
3,964
thing is the car isnt runnign and its nopt really leaking. tis just soaked at one part. Car hasnt been turned on since winter began either. could it somehow be connected to me takign the 3000 pipe off and polishing. i still ahvent put the ic piping back on until i get my air filter.
NATAN666
yarrrrr
Apr 4, 2005
289
BC
user.dccnet.com
what they are tryign to say is that there is no physically possible way the coolant is coming from your intercooler. Maybe somebody was topping off your overflow tank and spilled it on the IC?
your IC is just really beat up, so i am not going to disagree with your decision to buy a new one :p
Mr.PFloyd
Jun 22, 2005
3,964
aww why u be a hater haha. but seriosuly i hate those damn rocks. oh and i knew what they were trying to say... its just werid because on top of that there is no coolant on the ground yet when you touch it its liek freaking leakign down your hands.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
i looked at mine and the over flow drain from the OF tank dumps right onto the IC? might explain the coolant there..
shaeff
11
Around
that's what i said. ;)
-shaeff
shaeff
11
Around
CryoSLash said:
but would it still be pressurising if i havent started it in a long time?
eh, no. if anything, it should have sucked the coolant INto the motor.
-shaeff
LoveMy7MGTE
162
Grosse Pointe, Michigan
-shaeff
when i did my bgh fix i DID have coolant inside my intercooler. i was pissed, as I had to remove the bumper to take it out and empty it. for future referance, is there an easier way to remove stock IC?
shaeff
11
Around
i just pull mine in and out from the bottom... easy as pie.
and joel, it's all good buddy!
-shaeff
Mr.PFloyd
Jun 22, 2005
3,964
k today morningright before school, i tried to get a second look and get some more on my hands of this liquid. today it was gone. i bet it was just a lot of overflow that i guess didnt leak just attached itself to the IC. thx for all your help guys, i was a little worried there..
