Universal radiator?
Doward
4,245
Alachua, FL
Stock radiator I just paid $188 total for -
(including tanks)
18.5" tall
26.5" wide
single core, 1" aluminum.
I'm thinking of returning it, and ordering this instead -
Griffen GRI-1-25222-X from SummitRacing.com
(overall size)
19" tall
26" wide
3" thick, dual 1" tubes.
$190
The problem I'm seeing (besides building brackets to mount it) is NOT the fact that the inlet size is 1 1/2" (which is really close to stock, I think I can stretch the hose a bit to fit) but the outlet is 1 3/4". This stock radiator seems to have a 1 3/8" inlet, and 1 1/2" outlet. Not sure if I can stretch the lower hose - the real problem lies in the fact that the inlets and outlets are in different locations.
Now, the upper hose from Autozone is just a 90 degree hose, that you have to cut anyway - the location of the upper inlet seems to be about the same - just shifted down about 6". I don't recall how much I took off the hose, but I'll check into that - I think it was about 6-8"
The lower hose, however, I'm a little more worried about. I'm thinking of finding a 45" aluminum bend (or stainless steel, if I can't find aluminum) 1 3/4", and cutting/modifying the stock hose to fit.
I used to have this exact same radiator for my '77 Firebird, and I remember the lower outlet is angled.
I'm trying to get some feedback from anyone that's done this before, or has heard anything about it. It seems I lose the fan shroud in the process - will the extra cooling capacity offered by the better radiator, offset the lesser airflow without the shroud?
There is also the benefit that this forces me to an external transmission cooler - that is that much less heat load going into the cooling system ;) for a total price difference of about $50 vs a stock replacement.
Doward
4,245
Alachua, FL
Good point... It is a 1/2" taller, but I didn't include the stock filler neck in those calculations... I'll have to double check that tonight!
I thought about going with a PWR or a CSR 2880 - but I still have to get an external cooler... so I'd rather build some brackets for $8-$10, and put the other $110 toward something else for the car... Maybe go ahead and build my intercooler hardpipes :)
Doward
4,245
Alachua, FL
Ok, I think I see what you mean - looks like there is a brace under the hood in that location that could pose a problem... Gonna go check out FnF3 now tho, so I'll look more into it later
Doward
4,245
Alachua, FL
eh, movie wasn't so bad. Better than the first two, imho :)
Anyway, I'm going to check it out more in the morn, so I'll report back then.
