Under Drive Pulley
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
how can one tell if the harmonic balancer is still good? or can they even go bad....
i read a wiki article on them and I guess some can... but I dont know enough to tell if ours can.
figgie
Twin Cities, Minnesot-ah
well
quite simple really
look at the rubber portion. If it looks cracked and falling apart. That means that the entire rubber portion is cracked and brittle. In other words it is not dampening anything.
On a 87 supra. That will make the pulley 21 years and counting. Too old to be worth anything.
Figit090
Jan 7, 2006
1,835
Humboldt County
i guess i haven't looked carefully at my pulley yet. all i see is a pulley. haha....
where should i look on the pulley? i dont have to remove it, do I?
AJ'S 88NA
2,419
Florida
There's a rubber ring on the inside about an inch in from the outside edge. If it's dryrotted it will show. Hard to see with the fan shroud in place as you have to look on the front of the pully to see it.
