ugrades while head is off
snyder250
78
california
hi ive recently had a case of BHG.i bought arp studs and will order the correct MHG when machine shop tells me which diameter. i was wondering what mild upgrades i should do while head is off.i dont wana go crazy or mess with air fuel ratio.(Im new to this as u can tell).what would u guys sugjest?upgraded valves/cam or like a port and polish on the head.any input would help.thanx
Suprapowaz!(2)
2,870
San Antonio, Tx.
Save your money on any upgraded head work and spend it on a better turbo & fuel upgrades. That's if you haven't already done so. I wouldn't do any more than just a vavle job and mill it straight.
radiod
1,342
Abbotsford, BC
A VERY cheap and relatively easy thing to do is to get two of the Comp Cam 975-12 boxes of valve springs and stick those in in place of the stock springs. Higher seat pressure for about $60, plus you get nice new springs to replace 150,000+km springs. They are a tight fit, but it works :). The only other thing I did with my head off job was a bit of home porting and polishing. That took a long time, but if you've got the time, why not? Just make sure you read up on what you're doing before attempting that, because you can seriously mess up the flow in your head if you screw up.
mkIIIman089
Ohio
Definitely have thread inserts put in for all of the exhaust studs.
Some valve springs would probably be the only thing I would bother doing, help put you at ease if you decide to go with some bigger cams down the road.
mattsplat72
is sofa king
Jan 17, 2006
1,738
Replace your rod bearings. Alot of people get rod knock after the BHG. I did in about a week. While you are at it might as well do the OIL pump mod as well. It is a little more time but with these three things fixed/upgraded you will have a more reliable 7m
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
That depends on where the gasket was/is leaking from. So the is question was the coolant going into the oil pan or going into the combustion chamber ….
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
I hate heli-coils; but, thread inserts would be good to install on the exhaust side.
Knock sensor mod wouldn't be a bad idea either.
mattsplat72
is sofa king
Jan 17, 2006
1,738
Man I don't know, you should find a post with supracentral and look at his Sig for a get link to a rod knock thread. Me personally I would do them.
Did you pull the motor? I didn't and I wish I would have. My advice just look around and check everything in sight and fix or replace anything that seems iffy. Hows your starter if is is suspect now would be a great time to replace.
snyder250
78
california
i actualy just did my starter.th motor was rebuilt also.i let my mom take the car for a couple days and it over heated.and of corse instead of stopin she thought..."its just round the conner.ill make it".i did order a silicone hose set.would porting the intake manifold or head do any thing worth wild?thanx 4 the input u guys.
