twin walboro wiring help?
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i'm getting ready to start wiring my pump's.i plan on running seperate relay's for each pump and there own power feed from the battery.i'll also use the stock power wire to trigger the relay's.
the only thing i'm not sure on is wire and relay size,because the thread's i've read made no mention of this.i have a full roll of 10awg that would be enough for two feed's from the engine bay to the hatch.i was figuring two 30a single pull relay's.
what do you guy's think?any input would be great.i know there's alot of guy's running twin pump's
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
easiest and simplest way to do it is get some 10g wire and wire them to a switch. go from batt. to switch to fuel pumps. just remember to turn it on before you try and start the car. lol and make sure and use a in line fuse with in 12 in. from the batt.
crazysupra2JZ
740
Georgia
i did that.
it's where the coin box used to be
you just have to remember to turn it off before you leave the car. i wired in a light to remind me. you get use to it after a while
14 AWG should be fine. it's like $7 for 100 ft from Summit
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
to actually answer your question ;), 2 12V, 30amp relays will be just fine. Head over to radioshack, i think they're 6 or 7 bucks each.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
^^^ i'm most likely doing that.not really a big fan of the pump on a switch method,unless it was on the trigger wire to kill both pump's.
