tissimo said:I did have everything for the TTC I pulled it all off as the downfalls of the system outweigh the benfits..
running the single #1 turbo at 15 psi is like running the twins at 30 psi.. The single turbo is flowing 2x the amount it should, on elivated boost levels it makes it even worse..
I'm pretty sure the ecu activates #2 at 4k+ I think around 4500... So it will not kick on before that
NO. #2 is pre-spooling before the IACV opens. It is not surging.tissimo said:so #2 will surge until 4k when the iacv opens.. sounds like a winner to me..
tissimo said:Still doesn't do anything to counter act the #1 turbo overspinning to create 15+ psi in the intake
tissimo said:yes it does have more torque from 3000-4000 but its not that big of a difference..
If the turbo is spinning and the compressor isn't flowing it will surge, just like your throttle body closed when the turbo spooled.OneJoeZee said:NO. #2 is pre-spooling before the IACV opens. It is not surging.
If the IACV opens BEFORE the EGCV, then yes you will have problems. IF it opens before it may cause surging(not always) and #2 to spin backwards. If the system is working how it should this does not happen and the IACV opens AFTER #2 has sufficient exhaust energy and boost. So when the IACV DOES open, #2 is already pre-spooled and joins #1 just fine without any surge. The system would be a complete failure if #2 had to experience surge. But it doesn't.
Because 1 turbo is Flowing 15 psi. If you add in turbo 2 the flow is cut in half for each turbo. I probably shouldn't say overspin, cause I dont have a compressor map of the ct12b and cant tell for sure, But I'm sure its running extremely high rpm and causing accelerated wear on the turbo.How is 15psi considered overspinning? If #1 spinning 15psi is bad, then both spinning 15psi is just as bad. 15psi is 15psi whether it's from 1 or both. Number one is not the commonly reported failure. It's #2 and for the reasons I wrote in my last post.
trueMaybe not to you. The point is to provide the OP with enough information to make that decision for himself.
The Reaper said:wrong Joe....
it doesn't even start prespooling #2 until 4K and then it kicks on fully at 4500. tissimo is correct. i prefer ttc.
The MKIV Supra's twin turbos operated in sequential mode instead of the more common parallel mode. The sequential setup featured a pair of small, equally sized turbos, with ceramic blades for the domestic Japanese market and steel blades for export (USA, Europe) markets. At first, all of the exhaust is routed to the first turbine for reduced lag. This resulted in boost and enhanced torque as early as 1800 rpm. Approaching 4000 rpm, the exhaust is routed to the second turbine for a "pre-boost" mode, although none of the compressor output is used by the engine at this point. Approaching 4500 rpm, the second turbo's output is used to augment the first turbo's output. This setup differs from other twin turbo designs which run both turbos in parallel. The sequential mode provides greater low RPM response and increased high RPM boost.
tissimo said:If the turbo is spinning and the compressor isn't flowing it will surge, just like your throttle body closed when the turbo spooled.
The Reaper said:ok well i got that from wikipedia so i dont see how they get two different answers
but you're a supra god and im not. my bad.
for the original poster i still say TTC but do whatever you want
tissimo said:I still say ttc.. keep #2 alive..
hahahaOneJoeZee said:I give up. I already refuted that. #2 dies because something is malfunctioning in the system. It does not die simply because you are running sequential. This is like the 1J myth about boosting over 1bar. If seq. truly caused the 2nd turbo to die, everyone running sequential would have a dead 2nd turbo. It is true that many have experienced failure of the 2nd turbo running sequential. It is also true that many people have faulty sequential systems.
Correlation does not equal causation.
What are you going to tell people who ask about how to raise the boost on their 2J? Run stock boost... keep #1 and #2 alive?
Do as you wish, as long as you're enjoying your car.
tissimo said:hahaha
But seriously what would not function correctly on the Sequential system to cause it to be more prone to blow #2? Only think I can see is if the timing on the EGVC and the IAVC arn't right cause surge or IAVC opening too early or maybe even the EBV not opening so the turbo is at 0 rpm when the ebvc opens. You can not control any of this, the ecu does. Now if the VSV doesn't work or is broken then yea, but you will notice something is up doe to abnormal boosting.
OneJoeZee said:There are some important parts that pertain to the failure of the 2nd or both turbos. One is the intake air control valve which is located in the intact tract for the 2nd turbo. It's closed before 4000RPM so the boost pressure from #1 does not travel back to #2 and cause it to spin backwards. #2 is pre-spooled around 3500 but doesn't join up until 4000. There is also the exhaust gas control valve which allows #2 to get spinning at it's full rate before joining in with #1. When that happens the IACV opens and they both join together and you're fully online then. The EGCV has to open before the IACV for the 2nd turbo to be safe. If the IACV opens before the EGCV, the pressure from #1 will travel backwards through #2 and will spin backwards if there is not sufficient exhaust energy to keep it moving forward. When the EGCV opens after the IACV, the 2nd turbo has to not only build up boost quick but it has to reverse direction due to the IACV opening causing it to spin backwards before it had sufficient energy to keep it going forward with full pressure. That's what puts all the strain on the shaft and bearings of #2 causing it's failure.
The exhaust gas bypass valve is what allows #2 to prespool at 3500 and is there to smoothe the transition between 1 and 2.
If any of those aren't working, quick death of the 2nd turbo usually occurs shortly after. A proper seq. system with all VSVs working as they should will not just kill the 2nd turbo.
tissimo said:Now sequential might not blow your turbo any time soon, it may last several years, it just simply causes more stress on it.. I didn't want to risk it, as I didn't want to pull the engine to get the turbos off (I highly doubt you will be able to get them off in the car). Lag isn't that bad at all (I'm making 300 ftlbs of torque by like 3500 rpms), and I can gain a few extra HP from removing the valves all together. So I went TTC.
