http://www.turboneticsinc.com/products/index.php?products_id=16&category_id=2
Does anyone use this mbc with CT-26? I've installed one, but there's a weird issue. I don't get the boost until the engine has been running for about an hour. MBC is installed under the bonnet. Could it be somehow related to the temperature? It seems this MBC is just not working (like fully open) when the car hasn't been driven for a while. Maybe it's jammed in opened position and it releases after some while... which is unlikely, because then there should be an overboost.
I know it states "dual port actuator only", but I was able to hook it up like ordinary MBC and it works fine (when it works at all, and I don't know the reason why it shouldn't). Actually I don't know if it's MBC issue at all. Please, don't post if your solution is to change BC or get an electronic one. I'll do so when other priorities are fulfilled.
