turboing a 7mge with out using turbo electronic's
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
Well i am about to try this mabye
idea
7mge
apexi neo
possible 7mgte injectors (might just use stock) if i can
no inter cooler
stock turbo with lowered boost about 5 pounds
and mls hg
any one hvae tried this as you can see this is really budget setup so far
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
no intercooler? I would think 5 psi is still a lot of boost for a non-intercooled, high compression engine. I'm sure it'll work for a little while and it would be quite peppy, but i wouldn't expect it to last long.
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
bioskyline;1826195 said:
weaker W/G spring,
Like I said, how do you do that on the ct26? It's internally gated, are aftermarket wastegate actuators available for it? I'm curious because I'd like to lower the stock boost on my ct26 so that I could set a more effecient duty cycle on my Apeki AVC-R for my boost goal.
Devin Hutchison;1826216 said:
Lol @ no intercooler. You obviously have very little understanding of how a turbo works. No, don't do any of that. Do it right or don't do it.
Sent from my PC36100 using Tapatalk
Look at his signature, he understands plenty.
Poodles;1826408 said:
Apparently he really likes building grenades...
I'm thinking....::popcorn::
Jimbo
Creeper
Jul 15, 2009
263
San Jose
Fuck it nigga just go for it. As long as it aint your DD it sounds like a fun little project even if it does eventually blow up.
You should probably use an intercooler tho.
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
Yea I take back my DD idea, 'cause after all of your guys's posts I'd worry too much if I was the OP.
mecevans
1,295
M-bay, cali
Nash,
Is this going in the truck? If you have the parts laying around seems like a great idea. Just make sure the cooling system is up to it. The 5M guys also stiffen up the AFM.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
yae it will be going into my bush truck
so no inter cooler.... it just wonte do nothing any ways my truck does not move when trying to make it up rock face's and i want fast spool
oh I forgot to add in the fuel reg but I know about that
rad will be monuted in the back by my fuel cell
afm will have to be mocked with I know that
ps it's very easy to lower the boost on a stock ct26
2 ways of doing it
make the rod slighly longer or grind the compser houseing down
done it before works fine only can go so low thou
over all plan thus far is to keep it tame no huge power 200 to 220 is all I want for power
timing is the only thing. but I could just run the system in closed loop to lower the timing map if it's going out of hand
-text removed by toyotanos-
NashMan
Aug 5, 2005
4,940
17
Victoria BC
boooooo buddie sold the donner car on us boooo
oh well
all stick my my quarter 7m / 22re motor for now
