turbo
Thattechguy
11
Adkins, Tx
:1zhelp: I did a search prior to this but found diffrent answers to my question which is to follow. My stock turbo has took a dump, the shaft is wobbly, so I want to install a t-3/t-4. Will this be a problem? Is the flange a direct fit? Do I need to upgrade anything else? BTW my engine is a stock 7mgte. Thanx
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
You could get an ebay chinaman manifold that has the right footprint. You will have to make a downpipe and probably the oil feed/return lines. You could always get your ct26 upgraded. That would be your best bet since it is bolt on.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Not to mention cut off the wastegate flange and fix it so one will actually fit and work with it. An upgraded CT will most likely handle any power that you so seek for a long time ;).
kracin
Sleeper
Apr 1, 2007
68
aiea hawaii
check out sp (soundperformance) for turbos, they are a great seller for supraforums and make a line of bolt ons for the 7mgte, i just bought a sp67gt (67mm non ball bearing, they also make ball bearing, and do 3 or 4 inch sizes), pretty much whatever you want in a bolt on stock style with internal wastegate still. 1270 about for that one, good price imho
Thattechguy
11
Adkins, Tx
Is that just a kit off ebay or something?
NewWestSupras talk to Jeff Tamulis, he's the man for turbos...
is he on here?
