Turbo to NA???
RPSil13
464
Anaheim, CA
cant find any info on going from turbo to na. any help would be greatly appreciated
basically i have a 91 turbo shell and a good +89 7m na motor, but i cant find out much info on what i would need to make this happen, so far ive notived that the plugs behind the glovebox dont match up :3d_frown:
anything else i should be concerned about???
mecevans
1,295
M-bay, cali
all you need is the wiring harness/ecu to be from the same time frame as the car... pre89 or post 89. If you have a donor car it should be no brainer.
Greek
513
Ohio
You'll have to use the N/A tach cable.
You can go to the N/A-T thread and other than the obvious parts, see what is different.
leftynridge
401
dayton, ohio
Sale the na motor and buy a good turbo motor. It sounds like you could end up spending some what close to the same on either buying the additional parts you will need to go NA vs. just spending the different on buying a turbo motor once you sale the na. Plus you will probably be much happier in the long run.
