turbo timer
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Take the plastic off your steering column, and the panel below the steering column, basically everything to get to the wires under your steering column.
You'll see the plug you have to put the harness into, and it's just plug and play from there.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
mk3concepts said:
they were in japanese..i couldnt read it..seriously they were in japanese haha and the pictures..have no clue what they were trying to tell me so yah
i quote form the manual "put socket in wind and make wind with wires fly with force" :evil2:
Macabuhay
Corona, California
OK, sorry to revive such an old thread, but I am having some difficulty finding where this plus goes beneath the steering column. Can anyone help me locate this plug.
Also, the TT i have came with a harness that has a three prong end, is this the correct harness?
Thanks in advance!
Caplax40
Grand Tourer
Feb 12, 2006
202
Boise, ID
Sounds like the right harness. I have an HKS timer is well and still can't get if figured out. The term "Plug and Play" for this thing is a joke.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I just had mine installed, and weenied out and payed somebody . He tried to hard wire it and skip the harness the first time. He worked on it for 2 hours, and then realized the harness was gonna be needed. So he ordered it, and I had to come back. On the 3rd trip he finally did the work. It took him 15 minutes with the harness (interior panels were already taken off). He just plugged it in, and ran wites for the e-brake and a ground. The e-brake arms the system, so that wire has to be there.
For the inconvienience of coming back 3 times, all I had to pay for was the harness. I was very cool with that, because I needed the extra miles to get my new clutch broke in anyway.
inline6
Whistle>Whine
Sep 22, 2005
208
SoCal
Guys just pull off the cover underneath the steering cloumn.
Look up at the harness going to the ignition.
Disconnect it.
Plug in the harness.
Plug in the Timer.
If you are running the HKS, splice the 3 loose end wires into the ebrake wire, RPM signal, and speed sensor wire.
I'm pretty sure that is all, and enjoy your fully functional TT.
(Note- my RPM has never read correctly on the HKS unit. There is a calibration but it is either way too high or way too low. I dont think it actually calibrates to exactly where the RPM's are but reads from a range. This is on a 1JZ tho so you may not have any problems with this.)
EdgeSupra
506
New Jersey
Dont think so.
My buddy's got a Blitz and he had to do it also.
It's so the timer knows that the car is parked and to leave the timer going so the car idles.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
The only thing the E-brake wire does on my Greddy TT is enable the feature of the car to shut off if the E-brake is put down (Someone hops in your car and tries to drive away).
If you don't connect the wire the only difference is it will keep timing out if the E-brake is up or down. (you can put the e-brake down, and still drive it without the key, but the steering wheel locks)
